584,849 active members*
4,470 visitors online*
Results 1 to 14 of 14
    Post 501 -Z AXIS OVER TRAVEL
    DEAR SIR,
    I need the help urgently, we have controller install on FANUC Series 18i-MB , installed on dahlih DCM 2213, controller having error 501 -z axis over travel. kindly need help plse help me I will be thankful to you.
    Nov 2007
    351
    Re: 501 -Z AXIS OVER TRAVEL
    Were is the machine at now ? Home position ?
    Any other alarms like APC ?
    Machine cord?
    Power Down and press and hold the P and CAN buttons while powering up. Hold till you see normal screen.
    Dear Ishingleton,
    yes its in home position , but when we ran the program , it gives alarms - z axis over travel, there is no other alarms , APC & MACHINE CORD .
    Quote Originally Posted by drdos View Post
    Dear Dr Dos ,
    we done this it comes normal but when we run any program it gave the same alarms .
    Nov 2007
    351
    On the 1815 Screen have you reset the Z axis home position ?------------You changed the Z axis drive you would need to reset this ?
    Quote Originally Posted by lshingleton View Post
    Dear Ishingleton,
    Actually machine is coming to home position and taking all the reference, but our programmer active the ATC arm and it got stuck then this error came , after that we manually close this arm and after that now after running the program 300mm - z axis give alarm, and we have not change any drive or any thing.
    Nov 2007
    351
    Check Value in Parameter 1320 0r 1321 as these should be your negative value numbers ?
    After you recovered the ATC arm does it require a one manual cycle to remove interlocks ?
    Dear Ishingleton,
    we forcefully by hitting we put the ATC arm back, we check the values 1320 and 1321, both are okay i donot know about the interlocks can tell us more
    Nov 2007
    351
    When machine goes into ATC condition it is going through a set routine and some of that is to limit axis movement ----------Can you send the machine to ATC position and do a tool change ?
    Is there a manual sequence button ?
    Confirm tool in spindle is correct one after completing first cycle
    PS what actual machine is this -3 axis mill but what manufacture and is there a ATC revovery sequence ?
    In the ladders you would be looking for ATC squence completed signal
    WE HAVE DONE IT BUT ATC arm did not work and -z axis is the same error
    Nov 2007
    351
    Check manual for complete atc recovery if you have it ?
    Dear Ishingleton,
    Have a good day, we have a problem in parameter settings now the problem looking to be solved , thank you for your time and help
    Nov 2007
    351
    You are welcome and good luck
  1. ZT2500 , MSG-501 , Not displaying X axis for upper turret
    By ONyX557 in forum Mori Seiki lathes
    Last Post: 01-07-2021, 07:19 PM
  2. SH-403 with MSG-501. Need set zero point for X-axis.
    By coldrex in forum Mori Seiki Mills
    Last Post: 05-09-2020, 11:23 AM
  3. WARDJet Releases 5-Axis Router with 3 feet of Z-Axis travel
    By waterjet expert in forum News Announcements
    Last Post: 07-19-2016, 06:50 PM
  4. need Z axis design advice- dahlgren engraver -> full Z axis- how much Z travel?
    By lkasdorf in forum Uncategorised WoodWorking Machines
    Last Post: 05-11-2013, 02:50 PM
  5. U Axis excess error + Y axis over travel?!!!
    By jaine in forum Uncategorised MetalWorking Machines
    Last Post: 01-09-2013, 06:45 AM
