585,877 active members*
3,081 visitors online*
    Yasnac MX 2 won't receive or drip feed files.
    Everyone,
    I have a Matsurra MC500v with a Yasnac MX2 controller. I have shop floor automations USB connect set up on it to drip feed and transfer programs through a RS232. Everything has been working fine. Recently, I tried to drip feed a program and was unable to get to it work. No parameters were changed and I spoke with the guys at shop floor. I did a test on the RS232 cable everything appears to be good. I was able to write a basic program and send it from the controller to the USB drive. It transferred with no problems. When I tried to send the file back, it would not receive it. I read someplace another guy had a similar problem and it was a board or something in the controller. Unfortunately I can not locate the thread. Has anyone else had this problem or have an idea of what's going on.
    Gary
    Feb 2021
    4
    Re: Yasnac MX 2 won't receive or drip feed files.
    Quote Originally Posted by GWILLY1578 View Post
    Everyone,
    Gary
    Hi .i have the same issiu with my matsuura 500 yasnac mx2.I need to dripfeed but i dont know how.
    i transfer easily program from pc to cnc, but the memory is to small...
    Jul 2022
    5
    I'm in the same situation as you 2048
  1. Need help with Yasnac MX-2 DNC (Drip feed) error
    By nweisz in forum USB, RS232, PARALLEL etc
    Last Post: 07-22-2020, 02:06 AM
  2. Yasnac MX1/2/3 Drip Feed DNC Question
    By DMaz in forum Uncategorised MetalWorking Machines
    Last Post: 12-30-2018, 04:13 PM
  3. Drip Feed to Yasnac LX3 vis RS232
    By Zig in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-21-2008, 02:24 AM
  4. EZTRAK DX Won't Receive File from PC
    By hlp00001 in forum Bridgeport / Hardinge Mills
    Last Post: 03-19-2006, 12:10 AM
  5. Just found out I won't be able to drip feed w/RS232
    By jderou in forum Bridgeport / Hardinge Mills
    Last Post: 05-29-2005, 09:36 PM
