Hello,
I need help to modify a Fanuc post on AlphaEdit such that the post assigns N line numbers to every tool change in the code.
If anyone could advise me on how to make that possible it would be much appreciated.
Thanks in advance.
Hello,
Thanks in advance.
did you find how to do it ?
If you only want line numbers at the Tool Change and nowhere else remove all the N[N] codes in the Post using Replace (Find and Replace text),
then search for the $80 section of the Post and place a N[N] at the beginning of the line in that section you want the line number.
i.e.
$80 Select new tool. Use [T] for new tool number, [S] for spindle speed.
( [TNM] )
N[N] T[T] M6
G90 G10 P[OFS] R[TL]
then search for the $715 section of the Post and change the Line Start Number to what you want
i.e.
$715 Line start number
10
and the Line Number Increment to what you want
i.e.
$716 Line number increment
10
thanks i will be change the post
Hello. I need a little modification too.
I want to add nested sheet with and height at begining as info.
for example
(3200x1250)
is there a variable ?
any advise appreciated.
Thank you
