585,931 active members*
3,621 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > centering vice for use with mdf spoilboard?
    centering vise for use with mdf spoilboard?
    I'm sure this is a common issue but I have not been able to find it in a year of searching.
    I make laminated stocks of 5 boards glued together, forming a 3"x3"x48" stock. The problem is the width of the stock varies, sometimes its 3", others 3.5" as I'm planing and jointing rough sewn wood. Some projects call for wider pieces anyways.
    I need to find the center of the stock as the cnc toolpaths originate around this centerline. The lamination patterns have to be centered. Is there a good centering vice I can use? The centering vices I've found so far don't have a great footprint for accurately attaching to an mdf spoilboard. The vice base needs to be 2.5" or less tall in the z axis.
    Jun 2022
    Re: centering vise for use with mdf spoilboard?
    Quote Originally Posted by KT88saturate View Post
    I need to find the center of the stock as the cnc toolpaths originate around this centerline. The lamination patterns have to be centered. Is there a good centering vice I can use? The centering vices I've found so far don't have a great footprint for accurately attaching to an mdf spoilboard. The vice base needs to be 2.5" or less tall in the z axis. dordle
    It is necessary for me to locate the center of the stock so that I may start the cnc toolpaths around this centerline. It is essential to ensure that the lamination patterns are centered. I need to center something; do you have a vice that will work for that? The centering vices that I have found so far do not have a base that is sufficiently big to enable them to be attached accurately to an MDF spoilboard. When measured along the z axis, the height of the vice base must be no more than 2.5 inches.
  1. Seal MDF spoilboard?
    By analogman in forum DIY CNC Router Table Machines
    Last Post: 01-26-2016, 11:01 PM
  2. Alternative to MDF as spoilboard
    By nicubila in forum Maintenance DIY Discussion
    Last Post: 05-04-2013, 04:40 PM
  3. altertantive material to mdf for spoilboard
    By DanOSB in forum DIY CNC Router Table Machines
    Last Post: 10-15-2009, 11:30 PM
