585,604 active members*
3,421 visitors online*
Results 1 to 6 of 6
    Jun 2006
    138
    HES lathe retrofit help please
    I just bought a large NCS24 HES lathe. It looks to me as it was a hydralicly powered manual lathe. I want to remove the hydralics and use servos and convert to CNC. What would you recomend for servos and drives?
    Also what type of spindle motor and drive do I need?
    I have experience with retrofitting CNC mills but never a lathe. I know the spindle speed is more critical in a lathe. I plan on running the lathe with
    mach 3.
    Feb 2008
    280
    A year later...
    Did you ever get the HES retrofitted?
    I put a Centroid T400 on a 24NCS-D last April. That example already had DC servo motors, with a ca. 1979 McDonnell Douglas controller. We replaced those with 3kW AC motors and drives from Centroid. 3kW was probably overkill; the machine would have had plenty of torque with 2kW units.
    See http://www.cncsnw.com/HES24NCS.htm for pictures.
    Does yours have hydraulic slides, or hydraulic motors turning ballscrews?
    Jun 2006
    138
    Hello,
    Have not had a whole lot of time to work on the machine.
    I have purchased 3 KW sure servos and I have the X mounted.
    The machine looks good, mine is almost exact, except it doesnt have the turret. Do you know anywhere I could find a turret to add to mine? Also do you sell the centroid retrofit kits?
    Feb 2008
    280
    No specific leads on a turret, but you should be able to use a Dorian, Sautter, or just about any other aftermarket electric-motor unit. I don't know about aftermarket hydraulic units; they are probably available, if you prefer plumbing to wiring....
    Centroid sells an 8-position electric turret for $3,495, but I am not convinced it is heavy enough for a machine of this size.
    I do sell Centroid retrofit kits to customers in the Northwest and Intermountain West, and elsewhere as long as I am not stepping on the toes of other responsible dealers.
    Jun 2006
    138
    Can you PM me with your contact info?
    thanks
    Re: HES lathe retrofit help please
    hello i need the turret hydraulic scheme
  1. Help me retrofit a lathe with EMC please!
    By RP Designs in forum LinuxCNC (formerly EMC2)
    Last Post: 10-03-2012, 03:27 PM
  2. I want to buy a CNC lathe retrofit kit ??????
    By Jim Enos in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-12-2010, 02:02 PM
  3. Lathe Retrofit to CNC
    By Bobbyr70 in forum CNC Machine Related Electronics
    Last Post: 10-20-2008, 08:30 PM
  4. My lathe retrofit
    By HuFlungDung in forum Uncategorised MetalWorking Machines
    Last Post: 10-19-2006, 06:53 AM
  5. Lathe retrofit
    By toneV8 in forum Vertical Mill, Lathe Project Log
    Last Post: 07-01-2006, 04:41 AM
