585,933 active members*
3,815 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > Hardinge T42 Fanuc 18T can't load parameters
    Mar 2016
    I was too late replacing my battery, so I got "910 RAM PARITY (4N)".
    Restarting with CAN+P or CAN+RESET and then E-STOP get me to the same error screen.
    Restarting with "-" + "." gets a ROM WRITE/ERASE screen:
    I P L
    1. SERVO ROM WRITE
    2. GRAPHIC ROM WRITE
    3. SERVO ROM ERASE
    4. GRAPHIC ROM ERASE
    I can't find any documentation on this screen. I have a parameter file to download, but no screen. I've heard of others using CAN+RESET, but maybe that only works when the issue is not battery? Do I need to write ROM? What is procedure? Thanks.
    Aug 2008
    13
    Press reset+delete on power on .u should be able to get the basic screen.reload the parameters .
    All the best
    Quote Originally Posted by fadality View Post
    I P L
    1. SERVO ROM WRITE
    3. SERVO ROM ERASE
    I need hardinge conquest t42 parameters
    Can u send me please?
    Dec 2023
    4
    Re: Hardinge T42 Fanuc 18T can't load parameters
    Hello I have the same prablom on a Hardinge cobra 65 I was too late replacing the battery and Z axis is a 1 and the X axis is a 2 some one know how to help me
  1. Parameters for Conquest t42 w/Fanuc 18t model b
    By TassScott in forum Hardinge Lathes
    Last Post: 10-22-2019, 04:44 PM
  2. Replies: 2
    Last Post: 05-05-2019, 11:12 AM
  3. Replies: 0
    Last Post: 10-08-2015, 07:32 PM
  4. I.D. threading Fanuc 18t Hardinge T42
    By rwpbrian in forum Fanuc
    Last Post: 02-04-2012, 08:30 PM
  5. Fanuc 18T Hardinge T42 Grooving G-Code
    Last Post: 12-08-2011, 11:28 AM
