I'm looking for advise on spindle selection. First CNC mill build, looking to mill some custom heatsinks out of aluminium.
I've experience with building a 3d printer kit and have been getting good results from it. Good level of electronics experience, but none with milling or working with aluminium.
The structure will be this kit: https://www.makerstore.com.au/product/kit-otbv1-s-1015/
Driven by leadscrews, rated 9kg max on the Z axis.
A ~2.2kW spindle from China looks to be roughly in the ballpark I'm looking at.
In an ideal world it'd support ATC and rigid tapping, but research so far suggests that I may need to leave at least ATC for a future build.
Needing to water cool isn't a concern. It seems that water cooling results in slightly quieter operation, so would prefer this, however I'm not sure if this makes a practical difference in reality once milling the material.
Looks like rigid tapping will require an encoder on the spindle and some feedback into the controller so that it can coordinate the Z axis movement?
1.5kW seems to be a minimum to work with aluminium, so was looking at 2.2kW for a bit more head room.
Open to ideas / comments / suggestion. There are so many options, it's hard to choose...
