585,700 active members*
3,679 visitors online*
Thread: CNC Error
    CNC Error
    Hi there,
    We have a Biesse Rover A 3.40 FT and have an error message coming up.
    Error message- PLC9046 ( Slot tool- present sensor lacking (1 in 52).
    We have started the machine as usual and carried out calibration then loaded a program but the machine fails to pick up the tool.
    Many Thanks for any help
    Tim
    Apr 2022
    Re: CNC Error
    Hello
    There are three sensors in main head you must remove the cover, and you should be able to clean the sensors, probably is a lot of metal dirt on it, if that does not improve that means that the is sensor damaged and you will need buy new one
    Hope this helps
    May 2022
    4
    Re: CNC Error
    Try to restart machining without restoring the machine
    May 2022
    4
    Re: CNC Error
    I'm not sure that it's works.
  1. What type of error : Delta Internal Error![Movement Error]
    By asuratman in forum Mach Software (ArtSoft software)
    Last Post: 04-18-2021, 02:18 PM
  2. Replies: 0
    Last Post: 04-14-2021, 05:06 PM
  3. SCM Cyflex F900. Error cnc 1126 error calibration
    By Sandorin in forum CNC Machining Centers
    Last Post: 11-23-2017, 08:43 PM
  4. Replies: 8
    Last Post: 02-06-2015, 03:56 PM
