I need to press some oil-impregnated bronze bushings into cast aluminum parts with machined bores.. should I worry about the parts cracking if the tension is too much? Should I be looking at flange bearings or something to distribute the load?
Details: 3/4" ID bearings, static side load of ~75 pounds, momentary loads of up to 300-400 pounds.
