585,930 active members*
3,738 visitors online*
IndustryArena Forum > Maintenance in General > SERVICE FOR CNC-MACHINES > Goodway lathe black screen shut down
    Jun 2008
    5
    Hi all , I have this goodway GTS150 which developed a problem of random shut downs to a black screen , then it would power on again on its own , it has now developed into a no power on situation , there is 24 vdc at the nc power on button but when I press on I get the KA32 relay on the I/O board clicking rapidly and no power on , the drives are all lit up , the 24 v power supply voltage also drops when I press the power on button , any help would be much appreciated . I'm thinking maybe a short on the 24v system somewhere ?
    Attachment 479082
    Jun 2008
    5
    Re: Goodway lathe black screen shut down
    Quote Originally Posted by moss99 View Post
    Attachment 479082
    I found the issue , it was the head 2 ejector sensor wire had rubbed through and was shorting on a braided oil pipe,
  1. Black screen on 8040T
    By cevy08 in forum Fagor Automation
    Last Post: 09-06-2018, 04:36 PM
  2. Display screen goes black
    By CS900 in forum Esprit
    Last Post: 05-02-2018, 03:08 PM
  3. Goodway Lathe Coolant Pump
    By 57chevy in forum Uncategorised MetalWorking Machines
    Last Post: 03-22-2011, 06:33 PM
  4. ras2vec black screen
    By timmydabull in forum Mastercam
    Last Post: 10-15-2009, 09:21 PM
  5. Black screen
    By gamila in forum Fadal
    Last Post: 03-25-2009, 04:56 PM
