585,942 active members*
3,345 visitors online*
Thread: Help .
    Apr 2015
    6
    Exclamation Help .
    Hello ,
    I would need help, for something post does not give G1 to all G1 and if G2 is more than twice the order does not put G2 but thinks counts with one all out.
    can you help me, what should I change to achieve the result I want?
    G54
    N215 T21715
    G17 G98
    M23
    M90
    G0 C0.
    M89
    G0 X-29.442 Y8.287 Z5.
    G97 S1591 M51
    Z2.
    G1 Z-2. F79.5
    G41 X-25.442 F159.1
    X25.442
    G2 X31.442 Y5.287 R3.
    G1 Y-5.287
    G2 X25.442 Y-8.287 R3.
    G1 X-25.442
    G2 X-31.442 Y-5.287 R3.
    G1 Y5.287
    G2 X-25.442 Y8.287 R3.
    G1 X-21.442
    G40 X-17.442
    G0 Z5.
    M90
    G28 U0. V0. W0. H0. M55
    M30
    Dec 2018
    Re: Help .
    send me your post processor via inbox. I can modify it
    May 2007
    1003
    Re: Help .
    I don't understand your problem. G1/G2 in the program you posted are fine. Are you saying you want a G1 on every consecutive straight line move and if you break a 180 degree arc into 4 sections, you want to see 4 G2s (or G3s)? Why? They are modal and not needed on every line unless you have a machine that requires an output like that. If so, I'd suggest getting rid of the machine.
