Any one know of a place that might sell a 3/8 case hardened and ground shaft with a center hole all the way through about 4" long?
The hole can be small if some thing like that is even available.
Dennis
Dennis
Dennis
Dennis check www.nbcorporation.com under SNT "pipe shafts"
They have 6mm to 100mm od with 2mm to 60mm id hardened slide shafting.
DZASTR
Also check out Misumi, they have tubular shafting in different materials, also they have started including Imperial as well as Metric sizes.
Al.
Albert E.
