I have been using a cncest 6040 machine for a while with mach3 and it was working fine. A few weeks ago I changed the computer connected to it, also re-calibrated mach3. I think it was working fine for the first few times, but then I started to notice a slight downward creep of the z axis while linear machining. I recognized that if the z axis has to move more frequently, then the creep is more noticeable, but with almost flat designs it is barely creeping. Creeping means here, that the zero point of the z axis moves downwards as the program goes on..
I tried it with another computer, same results.
Do you guys have any idea, what it can be?
Thank you,
cnclevi
