Originally Posted by
mactec54
No, the A2 will only output what the spindle motor can draw, if you where to mess with the torque Parameters Pn13 and Pn14 in the A2 then your spindle could draw more amps than it should, Pn13 can be adjusted only once you have it working and can monitor the temperature
If the HY faults are not on the KeyPad screen, then you should just connect the spindle and run it, as per the normal wiring R / T / G, if the Faults are just in the advent folder they are nothing to be concerned about. connect the spindle and run if your Parameters are set correct
