586,011 active members*
3,905 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > chamfer mill: speeds/feeds on 1/8" steel sheet full depth?
    Hello all. Newbie CNC guy here. I've never used a chamfer mill before.
    Have project where i need to make 1/8" deep/wide chamfers on 1/8" hot rolled sheet/plate. The plate is 1' x 3' with some "windows" cut in it that need the chamfering. Mill is a converted bridgeport clone (CNC Masters Supra mill). I have a piece of plywood bolted to the bed, then sheet screwed/ clamped to wood. The piece is bigger than the travel of the mill, so i have a fence set up so i can move it around and do some features at a time. I hoping this works.
    I think it was the Harvey tool site that suggests chamfering in multiple passes. I have a 3/8" 2 flute carbide chamfer mill. I'm using fusion 360 for CAD/CAM. Right now i have it set to 2 passes: 1st one .088 depth, 2nd one to .125, that gives equal material removal. RPM is 2500 (mill seems to like that speed) and feed per tooth is .0007. This is really conservative i'm sure, but i'm looking for results and not breaking cutters.
    But is it too conservative that i'll burn the cutter?
    Please let me know your suggestions.
    Marty
    Re: chamfer mill: speeds/feeds on 1/8" steel sheet full depth?
    Curiosity got the better of me and i had to try my 2-pass setup. Results came out pretty good. Not too much chatter. A little more that i like in the corners, but that was expected. At .0007 per tooth i'm basically making "splinters". Wondering how much of a difference going up to .001 will make....
    Marty
  1. Speeds and Feeds - 25mm 3 Flute Indexable End Mill - In Steel
    By herrmc in forum Tormach Personal CNC Mill
    Last Post: 11-30-2018, 07:36 PM
  2. Replies: 2
    Last Post: 01-15-2017, 05:59 AM
  3. Feeds and Speeds and Depth of Cut
    By rodzilla in forum Uncategorised MetalWorking Machines
    Last Post: 05-21-2014, 01:54 AM
  4. 3" 6 Insert Face Mill Speeds & Feeds
    By Chalkboard247 in forum MetalWork Discussion
    Last Post: 10-13-2012, 05:20 PM
  5. speeds, feeds & depth ot cut
    By unclescott in forum WoodWorking Topics
    Last Post: 08-05-2009, 11:01 PM
