585,996 active members*
4,222 visitors online*
IndustryArena Forum > CAM Software > Esprit > How to change how offsets are called up
    Dec 2012
    13
    We have various citizen swiss lathes. When posting a program the tool call ups do not contain an offset. How do I change this? Example below.
    Currently the code looks like this:
    T0100;
    G0 Y? Z?;
    I would like it to look like this:
    T0101;
    GO X? Z?
    Thanks in advance
    Re: How to change how offsets are called up
    T0101, the second 01 means offset number 01, which should have been set in advance.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Jun 2022
    28
    Quote Originally Posted by cncmakers001 View Post
    what do you think of changing file extension. ? ??is this the way to do it? this is from autodesk
    To change the file extension for a Post Processor, perform the following steps:
    Open the .CPS file with a text editor like Notepad or Notepad++.
    Search for "extension" using CTRL+F.
    Change the extension in the quotation marks to the desired file extension.
  1. Meldas M0 - No work offsets? Tool change error?
    By MysticalDork in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-09-2022, 03:06 AM
  2. Meldas M0 - No work offsets? Tool change causes alarm?
    By MysticalDork in forum Mitsubishi controls
    Last Post: 02-26-2022, 10:47 AM
  3. Automatically Controlled Manual Tool Change Offsets
    By mrgame1988 in forum Mach Wizards, Macros, & Addons
    Last Post: 10-14-2016, 09:50 PM
  4. Replies: 51
    Last Post: 12-20-2014, 07:32 PM
  5. variable to change tool offsets in auto cycle
    By dalvinder in forum DNC Problems and Solutions
    Last Post: 09-04-2007, 09:45 PM
