585,917 active members*
3,429 visitors online*
    Sep 2019
    30
    Fanuc data collect
    Hi , I want to collect data(informations) from my CNC milling machine about : status of machine, how many hours was running(cutting), status of signals, load on servomotors, etc.
    I want to connect the CNC with a PC and collect this type of informations.
    My controller is Fanuc oi-MF.
    Any help will be appreciated.
    Jun 2015
    4154
    Re: Fanuc data collect
    hy rukam i can only help for okuma machines
    as for fanuc, i recomand to contact this guys : amit20 aadinug ablackwell; i don't know to what extend they can help you, but i saw them debating such things; there may be also others
    methods to gather data :
    ... fanuc dedicated or compatible
    ... generalisitic aproach that simply steals signal from any machine
    ... operating system based
    methods to process data :
    ... open loop : just record
    ... closed loop : record & react, like, for example, stop a drilling process if load is too high
    about this set : "status of machine, how many hours was running(cutting), status of signals, load on servomotors" :
    ... if you know the load, you know the status and how many hours the machine has worked, and other things this is good to diferentiate between what data you need to record, and what can be done with recoreded data
    ... status of signal : if i may, what signals do you wish for, and why ? kindly
    Dec 2009
    952
    Fanuc already have the software Fanuc MT-Linki for what you want to do
    Good luck.
  1. Collect data from old FANUC controller (RS-232)
    By jitbasemartin in forum Fanuc
    Last Post: 05-11-2023, 10:11 AM
  2. RS232 for data collect with Arduino.
    By LeDavida in forum USB, RS232, PARALLEL etc
    Last Post: 02-16-2023, 10:27 AM
  3. 2015 TM-3P, trying to data collect over RS-232
    By carboxyll in forum Haas Mills
    Last Post: 06-21-2019, 05:49 PM
  4. Haas Machine Data Collect
    By wmpy in forum Haas Lathes
    Last Post: 10-29-2010, 12:25 AM
