585,997 active members*
4,844 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > How do I connect servo dynamics sd4-1525 drives to Kanalog?
    Jun 2007
    22
    I'm trying to replace a dynapath 10 controller with Kflop & Kanalog on A lagun cnc mill. 1st question is what parts do i need to order from Dynomotion? 2nd question is how to wire it up? I'll ask about the Yaskawa VFD later.
    May 2006
    4045
    Re: How do I connect servo dynamics sd4-1525 drives to Kanalog?
    Hi marauder,
    Do the drives accept +/- 10V Analog Velocity commands?
    Do the drives output differential encoder signals?
    If so, you would need to order KFLOP + Kanalog.
    Its fairly straightforward to wire Kanalog's DAC outputs to the Drive inputs and the Drives encoder signals to Kanalog's encoder inputs.
    You might look at some User wiring diagrams in our wiki.
    TK
    http://dynomotion.com
  1. Servo Dynamics SD4-1525 Shunt Regulator
    By sliptonic in forum Servo Motors / Drives
    Last Post: 08-01-2021, 11:16 PM
  2. Servo Dynamics 1525-BR Manual
    By atgordon in forum Machinery Manuals / Brochures
    Last Post: 12-16-2015, 12:14 AM
  3. Replies: 1
    Last Post: 11-06-2014, 04:43 PM
  4. Replies: 0
    Last Post: 05-08-2013, 04:54 PM
  5. Servo Dynamics SD4-1525-10-3-10 chassis power needs?
    By erikjgreen in forum Servo Motors / Drives
    Last Post: 01-06-2012, 06:21 PM
