Re: Fanuc AC Servo Motor schould it turn ?
Originally Posted by
beemergb
My Bridgeport interact 720 has a Fanuc AC SAervo Motor on the Z axis , model 10 Typpe RO6B -0501 -B202 # 7000 , Ive put it back on the machine after moving into new premises , it was to high to get through he door ! Ok ,put it back on now I get fuses trppinbg out when I plug the sockets in the back og the ofthe n motor ! Ive taken the motor of again just incase Iveb done some thing wrong , and notice you cant turn ther motor on the axle / flange ,it moves a coupüle of thou and klonk both ways ! Can you normally turn the motor when off the machine ? Hope you can help thank you Harry
Place the plugs in one at a time to see which blows the fuse the brake, encoder and power are separate plugs.
Did you identify the fuse for which function?
I retro-fitted one on my shop lathe using a Fanuc servo motor that had the brake on it, the brake does show some slight play when it is on, (power off)
Albert E.
