585,568 active members*
3,262 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > FOCAS cnc_rdaxisdata function in the c#
    Oct 2021
    Post FOCAS cnc_rdaxisdata function in the c#
    CNC_RDAXISDATA from within the Focas library | POSITION I want to pull this function using the ready-made function below, but I am getting an error in the byte part, can you help?
    Absolute position, machine position, relative position, distance to go,
    of all axes are got and displayed.
    class example
    public void sample()
    Focas1.ODBAXDT_data pos = new Focas1.ODBAXDT_data();
    short[] types = { 0, 1, 2, 3 };
    short len = Focas1.MAX_AXIS;
    byte[] bytes = new byte[Marshal.SizeOf(pos) * 4 * Focas1.MAX_AXIS];
    IntPtr ptrWork = Marshal.AllocCoTaskMem(Marshal.SizeOf(pos));
    short ret = Focas1.cnc_rdaxisdata(h, 1, types, 4, ref len, bytes);
    if (ret == Focas1.EW_OK)
    int i;
    Console.WriteLine(“ABSOLUTE:”);
    for (i = 0 * Focas1.MAX_AXIS; i < 0 * Focas1.MAX_AXIS + len; i++)
    Marshal.Copy(bytes, i * Marshal.SizeOf(pos), ptrWork, Marshal.SizeOf(pos));
    Marshal.PtrToStructure(ptrWork, pos);
    Console.WriteLine("{0} = {1}", pos.name, pos.data);
    Console.WriteLine("MACHINE:");
    for (i = 1 * Focas1.MAX_AXIS; i < 1 * Focas1.MAX_AXIS + len; i++)
    Console.WriteLine("RELATIVE:");
    for (i = 2 * Focas1.MAX_AXIS; i < 2 * Focas1.MAX_AXIS + len; i++)
    Console.WriteLine("DISTANCE TO GO:");
    for (i = 3 * Focas1.MAX_AXIS; i < 3 * Focas1.MAX_AXIS + len; i++)
    Marshal.FreeCoTaskMem(ptrWork);
    Apr 2022
    Re: FOCAS cnc_rdaxisdata function in the c#
    Hello Mr. Emir. I want to collect data via Fanuc Oi-TF Plus.
    Working signal.
    counter signal.
    I need tag addresses for On which screen can I see these addresses?
    Thank You.
  1. FOCAS pmc_rdpmcrng function in the c#
    By EmirC in forum Fanuc
    Last Post: 07-04-2023, 08:35 PM
  2. FOCAS cnc_rddynamic function in the c#
    Last Post: 11-30-2022, 07:56 PM
  3. FOCAS. What is that?
    By Leha_Blin in forum Fanuc
    Last Post: 06-06-2013, 06:10 PM
  4. Fanuc FOCAS 31ib
    By abhthree in forum Fanuc
    Last Post: 01-17-2013, 06:19 PM
