585,599 active members*
3,576 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Using individual PSUs for each driver
    Nov 2021
    4
    Hello - I saw a 3-axis CNC machine yesterday that had 4 separate PSUs, all the same values. One for each driver, then another for the board. Each of these PSUs has 3 channels but only one is being used.
    It seemed extremely wasteful to me, but the engineer who made the machine (they sell them) said there's two reasons for it:
    1. It's easier for them to identify and service problems when a driver goes out. I have never heard of a single channel on a switching PSU going out without the others going out (correct me if I'm wrong, I'm no expert), so it would seem to me that point is of no benefit to them.
    2. When there's a lot of stress/load as the machine works, spikes in amperage use can cause interference/missing steps, etc. As far as I knew, as long as your amperage had a little overhead for the maximum usage of the drivers and board, you'd be all set.
    I did a little research and saw a couple people ratifying the second point there, but it wasn't specific enough for me to say whether or not it's a justified move to stock a machine with 4 PSUs when a single multi-channel, high amperage one would do the trick. I don't know enough about active/passive supplies, or electrical engineering in general to say this is all silly, so I come to you people. Is this actually a good idea? It seems like no money is being saved and there's no benefit to the company or the customer..
    Jan 2018
    1516
    Re: Using individual PSUs for each driver
    With regard to point number 1.
    You just junk the 1 psu on that particular driver.
    The initial cost of 4 small supplies vs 1 large supply is relative but.....
    In the future..... Replacing 1 small one is cheaper than replacing a large one.
    Switched psu outputs are in parallel so if one goes they all go.
    It's just so you can get all the wires you potentially need to attached to it.
    Mine has 4 supplies in it.
    80v for Z & C. (future plan for c)
    60v for X & Y.
    24v for main control boards / relays / sensors / servo driver.
    5v for controller itself / LPT I/O ports to control boards + step/dir etc.
    15362
    Quote Originally Posted by jtb00 View Post
    I'm with you on this there should only be one Power supply, there is no electrical reason to use more than (1) power supply, there is a reason why they do this though, and it is cost (3) lower watt Power Supplies are cheaper than (1) large one, ( about a $20 to $30 saving) when you get back to basics (1) Toroidal Power Transformer with all the voltage taps you need and each output regulated you can't beat it, SMPS advantage is low inrush current on start up, but no other advantage, both types have their place
    SMPS create a lot of interference (EMI) as soon as they are turned on, it is there all the time, no different when it is loaded that is just Bs
    Mactec54
  1. Output individual files
    By bspear in forum Fanuc
    Last Post: 02-26-2018, 04:36 PM
  2. Where to get individual 3040 parts?
    By bjzq8 in forum Chinese Machines
    Last Post: 12-03-2015, 04:20 PM
  3. Placing a large order with Reci Laser for Glass Tubes and PSUs
    By brcguy in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 04-30-2013, 07:52 AM
  4. Anyone know indepth info on laser PSUs?
    By Konstantin in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-14-2009, 05:00 AM
  5. power servos, PSUs
    By max_imum2000 in forum CNC Machine Related Electronics
    Last Post: 02-03-2006, 05:41 AM
