585,927 active members*
4,177 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > PUMA 2500Y Tailstock Jammed
    May 2022
    Issue with tailstock no longer retracting via footswitch or M code in manual. Tailstock is engaged against workpiece, was functioning properly earlier today. Tailstock traction bar is retracted and cannot function via M codes or buttons on control unit. No alarms, spindle and axis's stick move, just no way to retract or move tailstock. Any advice is much appreciated.
    Sep 2006
    222
    Re: PUMA 2500Y Tailstock Jammed
    Are other M codes working OK ? M03 ?
    If so, mu best guess is faulty valve solenoid.
    Look from el-pictures correct valve and check if voltage is coming.
    Jul 2005
    380
    Have you tried M12/M13?
    Sounds like a stuck valve or perhaps a prox switch
    Nov 2007
    352
    Did you unclamp the tail stock not the Quill ?--------Make sure the tailsstock is actually clamped first
