586,024 active members*
4,420 visitors online*
    May 2020
    15
    Expr.txt and issues with Inputs
    I recently created a script using the Expr.txt file, in order to check whether input 2 is activated before starting a program and to display an error message accordingly. I use an Mk3/4 controller by the way. Here is the short line of code:
    if (_hw_input_num|2==1 && _hw_isprog==1,exec(cmd('Machine.Emergency_Stop'),m sg("Emergency Stop: the security enclosure has been opened during a program. Please close it and start the program again.")))
    To give a bit of context, this input is connected to a reed switch, which is placed on the door of an enclosure surrounding my machine. If the door is open, input 2 is high and it is impossible to start a G-code.
    Everything works very nicely, but I started to notice weird behaviors from the controller when the door is open (input2=1). For instance, the homing procedure doesn't work correctly, but it starts working perfectly again if I close the door. If I manually jog an axis and I suddenly open the door while doing so, the motion stops or gets jerky if I open/close several times.
    Then I started to wonder if the issue also existed with outputs, and found the same problem. Even if nothing is connected to any output, turning on and off the spindle icon while jogging an axis will make it stop or get jerky as well.
    Is there any explanation of how the firmware/controller works to help me understand this? Or is it something else that I'm missing?
    Thanks for the help!
    Jan 2022
    107
    Re: Expr.txt and issues with Inputs
    I had some "funny" problems using expr.txt and it seems that the comparison with && does not always do, what expected. That may because of the used language for that syntax.
    So try the following first:
    change
    to
    if (and(_hw_input_num|2==1, _hw_isprog==1),exec(cmd('Machine.Emergency_Stop'), msg("Emergency Stop: the security enclosure has been opened during a program. Please close it and start the program again.")))
    Mar 2017
    1312
    @mgravet
    Please export your profile and send it to our support.
    @awpross
    "&&" is logic AND. Function "and" is bitwise AND. Logic AND function is "land".
    May 2020
    15
    @awpross, thanks for the reply. I tried to rework the syntax as you mentioned but the problem is still there.
    @planetcnc I just sent an email to support.
  1. [TNGv2] - Expr.txt
    By PlanetCNC in forum PlanetCNC
    Last Post: 05-29-2023, 06:20 PM
  2. Activate optional Pause in Expr.txt
    By awpross in forum PlanetCNC
    Last Post: 02-26-2022, 08:37 PM
  3. TNGv2 Expr.txt usage
    By theRat in forum PlanetCNC
    Last Post: 08-07-2020, 10:57 AM
  4. How do the inputs on the DSP controller effect inputs from CAm software
    By bensteele1994 in forum CNC Machine Related Electronics
    Last Post: 02-16-2019, 08:59 PM
