Have a wiring issue I need help with.
If I can figure out to post a picture here I purchased this machine used. After putting power to it, I can’t get the servo’s to turn on. I believe this is a wiring issue in the power panel in the back of the machine.
With no wire diagram I can’t figure out what needs to be fixed. If you have this same machine can you post a picture of the power panel on the back of the machine so I can check my wiring?
Brad
