585,877 active members*
3,194 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > I want turning machine ladder file for study
    Jun 2022
    Post I want turning machine ladder file for study
    I have software of fanuc3
    I want to learn that software.I have knowledge of ladder.I can understand rungs.I want lathe machine copy of ladder file ,for controller say oi mate or near to that.or any turning machine controller,
    that I can use it in fanuciii software.
    thanks
    Aug 2019
    145
    Re: I want turning machine ladder file for study
    Mill vs lathe has very little influence on the ladder.
    Most of the difference between the types lies in the NC program structure.
    Try to get a "Connection Function manual" for the control types you are interested in. You will see a few items for Mill or Turn but most are common. This manual will be very useful for your endeavor.
    As an example;
    Gear selection may vary. There is a parameter to select mill/turning type. But you could actually use either depending on circumstance.
    Much of the same logic / thought process goes into turning a turret vs a magazine.
    Turret - Unclamp, index to proper station, clamp.
    Magazine (simple) - Shot pin out, index to proper pocket, shot pin in.
    The logic for these two items could look virtually identical.
    Magazine (advanced) - Check magazine for requested tool, Shot pin out, index to proper pocket, shot pin in.
