585,753 active members*
4,123 visitors online*
    Oct 2007
    13
    DM 3300 Turret Drawings
    Does anyone have the mechanical drawing for the turret?
    I have a copy, but I think mine is a different revision and I can finish disassembly. My version had two taper pins into the part behind the toothed wheel that locates the turret rotation. I can't for the life of me get the toothed wheel out, and behind it are 8 bolts that I need to get to.
    Aug 2008
    405
    Re: DM 3300 Turret Drawings
    Attachment 480792This is what I have
    Oct 2007
    13
    Thanks, that's certainly different from mine. I feel like there's a press fit pin or something I'm missing.
    Nov 2012
    363
    FWIW, I wouldn't place a lot of stock in Dyna's drawings... I absolutely have the parts and operations manuals that came with my mill (I bought mine from the original owner of the machine), and I can categorically confirm that the drawings don't match my mill.
    Oct 2007
    13
    I did manage to get it apart, thanks for the help. It turns out out was fighting a previous owner's modification. I guess they didn't like the adjustment mechanism in the turret, so they added #4 taper pins in. I had removed those... but it seems they drilled them in-place (makes since). Because of that, it left a burr in the part that made it much harder to remove than expected. By reinstering the adjustment set screws, I was able to force the part to rotate in the bore. That helped in removale.
  1. 3300 Turret Static Tool Holder
    By keick in forum Dyna Mechtronics
    Last Post: 04-29-2022, 09:51 PM
  2. Please need help with Anilam MK 3300
    By JMG1 in forum Controller & Computer Solutions
    Last Post: 09-03-2020, 11:52 PM
  3. Anilam 3300 Networking
    By Teps71 in forum Uncategorised MetalWorking Machines
    Last Post: 05-24-2011, 12:21 PM
  4. anilam 3300 help
    By ninja11zx in forum CNC Machine Related Electronics
    Last Post: 11-18-2010, 07:21 PM
  5. drawing board drawings to cad drawings
    By mike hide in forum Uncategorised CAM Discussion
    Last Post: 03-23-2009, 10:35 AM
