Originally Posted by
JBrown4220
There are so many conflicting "opinions" on how to wire up a Chinese VFD/Spindle bundle. My VFD in particular is rated as a "110v 2.2kw" version.
My spindle (unplugged) had continuity from pin 4 to the spindle exterior, so I assume that means the ground wire was indeed hooked up correctly inside the casing.
Now plugged in to the VFD I cannot understand why I am getting continuity from anything I touch. Shouldn't the ground terminal not have continuity to the other leads (S & T on the VFD in my circumstance)
maybe I am just confusing myself, but seeing this I want to make sure it is safe before I burn up the equipment (or my house God forbid)
