585,967 active members*
4,116 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Milltronics VM2515 Electronic Spindle Orientation?
    Angry Milltronics VM2515 Electronic Spindle Orientation?
    Just replaced spindle belt on vm25. Now I am trying to reset orientation for tool changer. Haas has paramater 257 but Im stumped on milltronics 9000 control. Thanks
    Aug 2009
    1573
    Re: Milltronics VM2515 Electronic Spindle Orientation?
    Quote Originally Posted by MrAssBooty View Post
    ..try fixing the issue mechanically, which caused the problem ---- see what happens with Belt OFF the pulleys then... MDI M19?
    E-stop machine then, orient the Spindle pully add Belt
    The orientation position on older machines needed to be adjusted in the spindle drive itself and not in the control side. Not sure if this still holds true for the newer machines. You should be able to do what machinehop5 suggested and command a spindle orientation in MDI, then rough in the alignment by indexing mechanically. The PITA way is to MDI portions of a tool change (TC position, orient spindle, DB open, arm in), then jog the head up and down to check the alignment without crashing or flying toolholders in the machine. Hope this helps.
  1. Milltronics RW15D Spindle Orientation Parameter?
    By jsmith215191 in forum Milltronics
    Last Post: 05-13-2021, 06:45 PM
  2. Milltronics VM-17 vfd spindle enable, spindle test.
    By plane captain in forum Milltronics
    Last Post: 02-10-2016, 04:36 PM
  3. Spindle Orientation
    By Will_0000 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-01-2013, 03:29 PM
  4. Picomax 82 HSC-Spindle spindle orientation
    By QRox in forum HEIDENHAIN -> GENERIC
    Last Post: 07-21-2011, 03:05 AM
  5. Spindle orientation
    By jimecv in forum Daewoo/Doosan
    Last Post: 11-09-2007, 06:25 PM
