585,926 active members*
3,674 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC "do-it-yourself" > Building a Latche CNC... need help withunderstanding electronics requirements
    Mar 2010
    621
    I'm going to attempt to automate a lathe and wanted some user input and experiences on what electronics I should use.
    I currently use a G540 on my CNC and have found it very reliable but I'm struggling with the parallel port connectivity and that its for 4 axis, 2 un-needed. I'm also design unaware, meaning the G540 is nice package in that I just need to connect the servo's to the unit, power it and go. With steppers and drivers it's a little more complicated.. I think the setup is a Motion controller, BOB?, steppers, drivers and power source... is a BOB needed???
    I'd like to be able to use my laptop (Windows) and I would probably shy away from Linux.
    So, my questions are in no certain order...
    - Does it make sense to go G540 again and use UC100 to interface to my laptop?
    - Is it cheaper to simply go with 2 steppers and drivers and an inexpensive BOB?
    - If going the 2 steppers and driver route, are there suggestions for good reliable inexpensive equipment? I'm not looking for top dollar just reliability. I have Keeling motors on my current machine and have no issue with them, are there alternatives?
    - What Motion Controller should I be looking at? Warp9, UC300, K flop, etc.?
    - Reliability and ease of use, recommendations?
    Appreciate any input...
    Adam,
    Gecko G540, Rack and Pinion Drives-X and A axis, 1/2-10 5 Start Acme-Z Axis
    4-THK HSR 25 Linear Slides, KL23H2100-35-4B, Power Supply-KL-600-48 48V
    Mar 2010
    621
    Re: Building a Latche CNC... need help withunderstanding electronics requirements
    Please delete this thread...
    thanks,
    15362
    Quote Originally Posted by adam_m View Post
    Adam,
    A G540 may be a bit much seeing you only need 2 Axis for the Lathe, you still could use Gecko drives though, there are many good Stepper Drives also Leadshine make a good stepper Drive.
    If you already are using a UC100 then that is your motion controller, all you need then is the software Mach3, a Breakout Board and a Stepper Driver to suit the steppers you are going to use plus Power supplies
    I would use the Acorn Control which has a good lathe software package, UCCNC does not have CNC Lathe software and Mach3 Lathe software is not that great.
    Mactec54
  1. Building a new electronics box for my 6040, need advice
    By DaMaDo in forum CNC Machine Related Electronics
    Last Post: 05-30-2019, 01:52 PM
  2. building a PRO CRP 4' x 8' in Denmark need help with electronics
    By Gunni in forum Open Source CNC Machine Designs
    Last Post: 01-04-2014, 08:37 AM
  3. Replies: 5
    Last Post: 12-06-2013, 05:11 PM
  4. RF45 electronics requirements
    By forrest39 in forum Benchtop Machines
    Last Post: 05-18-2010, 06:52 AM
  5. RF45 electronics requirements
    Last Post: 05-17-2010, 06:37 PM
