585,930 active members*
3,901 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > After Update Gibbs doesn't cut to size
    Dec 2009
    20
    My post no longer outputs the correct size. I posted a 2 inch circle with a .375 endmill and it cut 1.875 circle. I programed to the inside so no comps should be required. But it was still too small. I could put cutter comps in but I want to program on size and add or subtract from Zero to adjust. Version 11.0 64bit
    Help Please!
    Itt
    15362
    Re: After Update Gibbs doesn't cut to size
    Quote Originally Posted by cousinitt View Post
    Help Please!
    Itt
    What did you upgrade to there was a Post problem with one of the different versions, which did affect some people.
    Just play with the Tool size to get it to cut the right size
    Check the settings it the Tool is cutting from the center or from the edge of the Tool
    Mactec54
    Sep 2005
    20
    It looks like your Default CRC selection got changed.
    Goto File:
    Click on Preferences, click on Machining Prefs, then Default Mill CRC. I would select Tool Center.
  1. Laser doesn’t cut probably
    By Evojf in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-27-2021, 09:27 PM
  2. Update Mach 3 2.62 to 3.042 version - LIMIT SWITCH doesn't run
    By EVHARTECH in forum Mach Software (ArtSoft software)
    Last Post: 04-03-2016, 01:50 AM
  3. Replies: 7
    Last Post: 10-22-2008, 02:38 AM
  4. Drawing Size and Cut Size Differ - Plasma
    By ADucci in forum LinuxCNC (formerly EMC2)
    Last Post: 10-05-2007, 10:52 AM
  5. Drawing Size and Cut Size Differ - Plasma
    By ADucci in forum Mach Plasma / Laser
    Last Post: 10-04-2007, 02:49 PM
