585,605 active members*
3,149 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Can you use a Lichuan Servo and a Delta Servo Driver
    So i bought this against some good advice i now see and i cant tune it, their software wont start and there manual is rough.
    https://www.aliexpress.com/item/2255...apt=4itemAdapt
    Wondering if i buy a delta drive, can i use this motor.
    both 2500 count encoders.
    https://www.digikey.com/en/products/...EaAoavEALw_wcB
    Jan 2018
    1516
    Quote Originally Posted by StarkRavingMad View Post
    The Lichuan is doable using the keypad. It's a ballache but doable. I only needed to do a few bits for analog spindle control. Never tried the debug software (yet).
    Do you have the driver disc and tx/rx usb/lan cable?. Did you change drive to master not slave and check baud rate?.
    Not sure about mixing drives.
    Craig (joeavaerage) is you best bet to ask. Depends how the wiring plugs are set up on the 2 units.
  1. Lichuan branded Servo & driver, yes or no?
    By dazp1976 in forum Servo Motors / Drives
    Last Post: 06-18-2020, 06:13 PM
  2. Possible to run Delta servo driver with lower power motor?
    By skrubol in forum Servo Motors / Drives
    Last Post: 03-05-2018, 12:27 AM
  3. Delta Servo Motor 750 W and Delta ASDA-B2 drive setup issues
    By johnansaro in forum Servo Motors / Drives
    Last Post: 03-02-2018, 06:16 PM
  4. SERVO AND CONTROLLER LICHUAN
    By carlosmedina in forum Servo Motors / Drives
    Last Post: 02-14-2016, 03:20 PM
  5. Change from yaskawa servo to delta servo
    By sachin.kumar in forum Servo Motors / Drives
    Last Post: 11-02-2012, 06:31 PM
