585,717 active members*
3,934 visitors online*
    Jun 2022
    16
    NC Studio-one profile cut to wrong scale
    Hello,
    I have been using Cam Bam and NC Studio on my new Chinese CNC with good results. However today I cut a panel, and all cutouts/sizes were correct, apart from one profile cutout (for an electronic connector). I assumed I stuffed up, but when I looked through the NC file, the code shows the X co-ordinates to be as I expected. The hole is appx 28% larger than designed.
    What could cause this strange issue?
    Any help much appreciated
    Jun 2022
    16
    Re: NC Studio-one profile cut to wrong scale
    UPDATE- found the problem, user error of course!!
    The shape was not closed, so when I programmed to profile inside, Cam Bam actually cut around the outside of the shape. Closed the shape and all good
    is nc studio cracked or origin ? if it cause lose steps in the process .
