585,753 active members*
3,776 visitors online*
Results 1 to 6 of 6
    Jun 2022
    axis reversed
    How do I flash my Cronos maker?
    all of the axis are reversed.
    15362
    Re: axis reversed
    Quote Originally Posted by tds0227 View Post
    Don't know that control but normally you can just change active High or active low to change direction in the control, or if you can't do that you can just change stepper motor wiring
    Mactec54
    Jan 2018
    1516
    Or if using mach3.
    There are 'axis reversed' checkboxes on soft limits page. Checking these boxes will also reverse direction.
    15362
    Re: axis reversed
    Quote Originally Posted by dazp1976 View Post
    Or if using mach3.
    No, that is only used if you want to reverse the homing direction, not the actual motor direction
    Mactec54
    Jan 2018
    1516
    That's interesting. Mine reversed axis direction as a whole.
    I must have had a 'useful' glitch.
    As you said before. The easiest way is change motor outputs 'dir' pin active high/low setting.
    (Leave 'step' pin as is).
    OP.
    All high/low does is switch IO voltage on or off to signal motor to spin in a particular direction. Changing it just reverses this action.
    Some people think it's actually a polarity reversal and aren't keen to change it. Is wrong.
    15362
    Re: axis reversed
    OP.
    No, you did not have a glitch, it will change the axis direction, but the X Y Z axis is changed by the active high active low, and how it moves in the Dro Positive or negative axis moves, this has to work correct
    This is the normal setup in Mach3 from the manual
    Now press the right arrow key on the keyboard. If all is well the X-axis DRO should count up
    and the tool on the machine should move in the positive direction (to the right) (table moves
    from right to left). If the DRO counts up but the tool moves in negative direction we need to
    reverse the motor direction. We do this by reversing the Dir Low Active setting in Ports and
    Pins, Motor Outputs.
    Mactec54
  1. X and Y Axis reversed - need help
    By designwerx1967 in forum Laser Hardware
    Last Post: 11-22-2016, 10:00 PM
  2. Z-axis reversed?
    By hjl4 in forum FeatureCAM CAD/CAM
    Last Post: 01-27-2011, 11:12 AM
  3. z Axis reversed - Resolved
    By JamesJames in forum Mach Mill
    Last Post: 04-23-2008, 02:03 AM
  4. Y axis reversed
    By Legion99999 in forum Syil Products
    Last Post: 03-04-2007, 06:43 AM
