585,942 active members*
3,327 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Morbidelli Author 500 communication problem.
Results 1 to 3 of 3
    Nov 2017
    Hi fellow members,
    One of my customers has a Morbidelli Author 500 that’s having communication issues. The problem is he doesn’t use it very often, after being off for around 6 months he used it once or twice and the next time he needed to use it Xilog3 would not communicate with the machine.
    I know the battery is dead, but there seems to be a backup of the parameters in the PC. When I open NUM Tools Machine Manager I can see A500_4.MCH, SUB_PGM.MCH and SIMBOLI.LIB files on the left column of the application. Unfortunately, when I click on Transfer menu all the options are greyed out (PC > NC, NC > PC and Delete).
    Another thing I noticed is that the red LED is on indicating an error on TSXFPP20 PCMCIA card. When I open XWAY Driver Manager and run XWAY Test FPC10 and UNITELWAY connects but the FPP20 gives an error “Cannot open the driver!”.
    Hoping that I’ve given enough information to shed some light on the issue at hand. I’ve brought all listed components back to my workshop so I can try all your suggested remedies and reply back to this thread.
    BTW I’m not a CNC tech, just an IT tech and CNC enthusiast that’s trying to help him.
    Thank you in advance and hope to hear from you soon.
    This is his setup.
    Integrated PC that’s running Win95. Xilog3 and NUM Tools
    NUM controller is 1020W
    SCHNEIDER ELECTRIC TELEMECANIQUE TSX FPC-10 card plugged into the PC
    A long cable and a Schneider Automation TSXFPP20 FIPWAY PCMCIA card plugged into the NUM controller
    Dec 2017
    Re: Morbidelli Author 500 communication problem.
    Hello,
    Did you find the problem?
    My friend also has same problem. The battery was replaced but still same communication problem.
    His NUM is 1040
    I am also just a IT guy and not experienced in CNC.
    Thank you very much in advance.
    hello you have to go where xillog3 is stored to open the bin bin nest xillog3
    C:\Program Files\Scm Group\Xilog Plus\Bin
    [COM]
    ;LINE=com1:9600,o,8,1
    LINE=com2:19200,o,8,1
    ''sorry for my english''
  1. Morbidelli Author 502
    By danarch in forum Commercial CNC Wood Routers
    Last Post: 02-28-2024, 09:19 PM
  2. Morbidelli Author 213
    By feechl in forum Commercial CNC Wood Routers
    Last Post: 01-30-2018, 08:51 PM
  3. Replies: 2
    Last Post: 01-04-2015, 03:51 AM
  4. Morbidelli Author 430
    By Scooby Doo in forum Commercial CNC Wood Routers
    Last Post: 04-27-2012, 02:32 PM
  5. Morbidelli Author 636 top
    By mwatkinson in forum Commercial CNC Wood Routers
    Last Post: 05-11-2010, 10:52 PM
