585,938 active members*
3,343 visitors online*
IndustryArena Forum > MetalWorking Machines > Bending- and Punching Machines > Amada Vipros 358 King II Return to Origin without using G50
    Hello,
    I'm trying to make a CNC program for an Amada Vipros 358 King II with a Fanuc controller. The program will have 3 pauses in it for the operator to rotate or flip the part as needed.
    The operator will start the program, the program will punch a notch, a radius, and a hole, then return to home and pause with M00.
    The operator will then rotate the part 180 degrees and resume the program. Program will punch some then return home and pause with M00.
    The operator will flip the part keeping the gripper edge the same. Program will punch some then return home and pause with M00.
    The operator will then rotate the part 180 degrees one last time. Program will punch some and then end with G50.
    The problem I'm running into with this program is that I'm getting a 4702 OT+ in the Y-axis when I try to return the axes to the origin using G70 X78.74 Y50.75 (X78.74 Y50.75 is the same as our G92).
    Anyone know what am I doing wrong?
    Thanks in advance for any help you can give.
    Jan 2012
    17
    Hi
    Your machine turret is Triple track, it means there are three tool set in a row with the same index pin. 1xx tools are inner, 2xx are center and 3xx are outer track. So they have a Y axis offset with each other.
    You can use
    G70“machine home position” T 2xx
    Or simply don’t use machine home position at G70 line. Subtract Y axis offset from Y value.
    Ex:
    G70 X1830. Y1200.
    M00
    But in this case the X gauge block may not raise.
    Mail me if the problem was not solved.
    [email protected]
    Good luck
    Re: Amada Vipros 358 King II Return to Origin without using G50
    Quote Originally Posted by norin1373 View Post
    Hi
    You can use
    Ex:
    G70 X1830. Y1200.
    M00
    [email protected]
    Good luck
    Thank you!
    This makes perfect sense and it solved my issue.
    I changed
    Code:
    G70 X78.74 Y50.75
    M00
    to
    Code:
    G70 X78.74 Y50.75 T229
    M00
    T229 was the next tool in the sequence, so it seemed a logical choice. The carriage returned to the home position and the operator was able to raise the x gauge block and reposition the sheet before resuming. We did a dry run first with punching off and then again with punching off just for the first stage, since we already had one part that had finished the first stage before triggering the OT+ error. We turned punching back on for the remainder of the program and it executed flawlessly.
    Thanks again!
  1. VIpros KIng 358 PHNC 2091 alarm
    By ehazpmf in forum Fanuc
    Last Post: 12-27-2021, 03:27 PM
  2. Vipros 358 king alarm 2017
    By jrmaxon in forum Fanuc
    Last Post: 11-23-2021, 03:17 AM
  3. Amada Vipros King 358 PHNC Alarm
    Last Post: 09-28-2021, 11:13 AM
  4. AMADA Vipros 358 king PHNC
    By megaman26 in forum Fanuc
    Last Post: 02-13-2017, 06:36 AM
  5. Vipros 358 king
    By larryr2d2 in forum Community Club House
    Last Post: 11-21-2012, 03:07 PM
