585,735 active members*
4,821 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > How to Calculate a 5.5Kw spindle motor machine actual power consumption
    I have bought my first ever machine from China.
    on the spindle motor, it's written that it is a5.5Kw and 16 Amp motor. it is 220v single phase.
    i highly doubt these figures.
    can anyone tell me how much electricity this machine will consume?
    thank you
    Attached Thumbnails Attached Thumbnails IMG-20220621-WA0009.jpg   IMG-20220621-WA0011.jpg
    15362
    Re: How to Calculate a 5.5Kw spindle motor machine actual power consumption
    Quote Originally Posted by awaisumar View Post
    thank you
    What is the Voltage supply and is it 3Ph or Single-Phase supply??
    Mactec54
    15362
    That would be a little low for a 5.5Kw I would say it should be closer to 22A and you will need at least a 45A 240v supply to run it and your machine, a 50A 240v single phase supply would be better
    So, when you only have single phase supply unless you have the Amperage, you should buy a smaller spindle to suit your power supply and Amps, the VFD Drive also has to have an input Amp rating to suit this as well or it will fail
    Mactec54
    Dec 2021
    31
    We produce DRO and grating ruler, maybe it will help you, you can go to https://www.amazon.com/stores/HHXXOV...2?ref_=ast_bln
    view on
    Or on Whats: +8613528773691
    Contact me at [email protected], [email protected]
  1. 2.2 kW spindleand steppers motor power consumption without load
    By Weyla in forum DIY CNC Router Table Machines
    Last Post: 02-27-2021, 08:16 PM
  2. Actual power consumption 100w tube
    By baronpork in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-21-2019, 06:55 PM
  3. Replies: 0
    Last Post: 03-06-2018, 08:41 PM
