585,708 active members*
3,674 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > Knocking noise/stepper losing steps, but only when laser is on
Results 1 to 7 of 7
    Jun 2022
    16
    Hi all,
    80W chinese laser with Ruida controller, Lightburn software. Has been working well up until today, no changes have been made (that I'm aware of-the machine is still new, is it possible to accidently reset factory settings?) Now the machine randomly makes a knocking noise, and I get missed steps resulting in broken lines, or straight lines become misaligned as the laser skips appx 0.5mm to the side. FYI I am cutting at 100mm/sec.
    Strangely, it only does this when the laser is active, if i turn the laser off, and run the same code, there is no issue.
    What could be going on here? Any assistance much appreciated
    Apr 2022
    135
    Re: Knocking noise/stepper losing steps, but only when laser is on
    Could be not enough power, if you said it would run cnc fine without laser.
    I would try different power supply or isolate laser on a different supply line and check how much it actually take.
    Nov 2013
    4358
    another possibility is that electrical noise from the laser power supply is being conducted into the power supplies for the electronics. Good quality EMC filters on each and all 230VAC inputs
    is a worthwhile investment.
    https://nz.element14.com/corcom-te-c...ase/dp/9586474
    Craig
    Jun 2022
    16
    Thanks Craig, I assume there is a laser power supply, and then a separate supply for electromics? Do you mean place a filter on each of the separate supplies, or is the filter installed at the AC wall socket to filter power from the source?
    Nov 2013
    4358
    I am presuming that there is a switch mode power supply to the laser, and that its electrical switching noise is upsetting other more sensitive circuits.
    You need to separate the 230VAC supplies, one to the laser supply, and the other for the PC/electronics. I would put a line filter on each AC supply.
    The filter on the AC input to the laser will prevent any noise from coming back out of the laser supply to pollute the 230VAC network, and the filter to
    the PC/electronics will stop any residual conducted AC network noise from being carried into the PC etc.
    Craig
    Jun 2022
    16
    Thanks, this is the setup, it looks like there is a power filter, but maybe only setup from the mains onwards (nothing separate for laser and electronics supplies)?
    Nov 2013
    4358
    I would put the line filter on the input to the electronics and/or PC and try it. The filter needs to prevent potential noise from the laser power supply from getting into the
    electronics, so the filter must separate the two.
    If it works then get two two stage line filters, the single stage filters don't attenuate the noise nearly as well.
    Craig
  1. Harmonic drive knocking noise
    By NORDLE in forum Linear and Rotary Motion
    Last Post: 06-20-2021, 11:34 PM
  2. losing steps on stepper motors
    By darylk0208 in forum Mach Software (ArtSoft software)
    Last Post: 07-05-2016, 11:00 PM
  3. stepper motor losing steps and stall
    By animalza in forum Stepper Motors / Drives
    Last Post: 05-04-2015, 06:59 PM
  4. Losing Stepper Steps Help Needed
    By halmande in forum DNC Problems and Solutions
    Last Post: 02-12-2007, 12:56 AM
  5. Losing X steps, stepper to small??
    By matth in forum DIY CNC Router Table Machines
    Last Post: 09-06-2006, 06:48 AM
