585,932 active members*
3,705 visitors online*
    output issues on NVCMV2.1
    I have a Mach3 with a NVCMV2.1 controller. I have configured the ports and pins as the manual says and can't get the spindle outputs or the normal outputs such output# 5 to operate. I am using "DoOemButton(235)" to turn on output#5, and it won't work. I have changed the driver, changed the USB cord, I have checked and rechecked the ports and pins setup. I must be missing something...Please help
    Apr 2022
    135
    Re: output issues on NVCMV2.1
    I think they all open collector outputs. There are no power on them just sitting transistors waiting for you to hook up power and load.
    http://www.learningaboutelectronics....tor-output.png
    You can provide power from VFD or controller itself, they offer +/- 12V for that reason.
    The photo on the link shows internal ground but your controller doesn’t have it .
    Dec 2022
    Perhaps you must enable your Ports - It only is a small hook in the software interface.
  1. CSMIO/IP-M Output/Enable issues
    By carlthomsen in forum CS-Lab CNC Products
    Last Post: 10-08-2019, 10:42 AM
  2. Issues with reduced power output on CO2 laser engraver
    By JohnnyMor in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-05-2018, 04:59 AM
  3. Pronest V8 issues with CNC output taking FOREVER to our Torchmate
    By Lockdown in forum Waterjet General Topics
    Last Post: 03-29-2013, 05:18 PM
  4. S-350-24 Output issues
    By Base in forum Maintenance DIY Discussion
    Last Post: 06-22-2011, 07:03 PM
