586,005 active members*
5,052 visitors online*
    Jul 2022
    4
    PROXIMITY SENSORS
    i AM A 100% NEWBIE. I am building my first machine. I have warp9 ess, cnc4ps BOB , Perrerl and Fuchs limit switches. Mach4. I have the sensors powered up with 12volt , the LED turns off and on when I place an object in it's field. The voltage will drop to 1 volt not sensing anything and 12 volt when it does. Because it always has one volt, my ess thinks it's has a signal all the time. I have tied active low and the limit switch reads on all the time. I have tried ever thing I can think of. Does anyone have any suggestion?
    Dec 2013
    5717
    Re: PROXIMITY SENSORS
    Wire a 1200 ohm, 1/4W resistor between the output and common (-12V). That should pull the output to near 0V, and draw about 10ma.
    https://www.amazon.com/EDGELEC-Resis...s%2C148&sr=8-2
    Jim Dawson
    Sandy, Oregon, USA
  1. 5v proximity sensors
    By nemisladkiv in forum PlanetCNC
    Last Post: 11-15-2019, 06:49 PM
  2. how many proximity sensors?
    By RobSm in forum CNC Machine Related Electronics
    Last Post: 01-18-2017, 09:02 AM
  3. Turck Proximity Sensors
    By vertcnc in forum Stepper Motors / Drives
    Last Post: 01-06-2014, 06:48 PM
  4. proximity sensors
    By FordGalaxy in forum Benchtop Machines
    Last Post: 06-02-2012, 09:36 AM
  5. proximity sensors
    By wired in forum CNC Machine Related Electronics
    Last Post: 09-30-2005, 05:29 PM
