585,996 active members*
5,070 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma Genos 460v-5ax keep chip augers from turning on.
    Sep 2016
    How do I keep the chip augers from turning on? I only ever want them on when I turn them on manually.
    Apr 2006
    822
    Re: Okuma Genos 460v-5ax keep chip augers from turning on.
    Quote Originally Posted by Underhammer View Post
    A REALLLLLYYY Sketchy way would be to trip the breaker for the augers.
    Not sure if that would alarm your machine out though...
    Apr 2009
    1262
    I believe that there is a parameter for the augers that determines if they start automatically or not.
    go to your parameters and look for the "Chip Conveyor" section.
    You didn't say what control you have, but since it's a Genos, it should have a newer control with that section in the parameters.
    Experience is what you get just after you needed it.
    Jun 2015
    4154
    hy maybe these are available also on your machine : mc user para \ no 1 coolant \ chip conveyor +
    ... turn on with coolant [ list item 22; use page up/dn to navigate ]
    ... turn on with nc run [ 23 ]
    ... turn off with reset [ 70 ]
    ... manual select continuance time [ 89 ]
    ... intermitent stop time [ 97 ]
    ... stop at alarm d time [ 123 ]
    ... stoped at alarm a/b [ 143 ]
  1. Genos M460V-5AX + Renishaw RTS (RMP-60 RMi-Q)
    By Sergeyrusa in forum Okuma
    Last Post: 05-31-2020, 11:37 AM
  2. okuma genos 560
    By rhegdahl in forum Okuma
    Last Post: 11-22-2013, 03:48 AM
  3. Okuma Genos L400
    By ad64075 in forum Okuma
    Last Post: 10-03-2013, 08:01 PM
  4. OKUMA Genos M560
    By karkudata in forum Okuma
    Last Post: 08-28-2013, 10:38 PM
  5. Anyone Have A Okuma Genos m560-v
    By Mountainwildman in forum Okuma
    Last Post: 01-14-2011, 06:49 AM
