I'm working on an old machine that uses the Magnum 400 drive amplifiers and need a bit of help getting it to work.
Everything works on the drives, I can jog the servos using the "digital speed" setting within "speeder one" as described in "motor test" in the manual page 43.
Manual found here https://www.axorindustries.com/wp-co....05-15-ENG.pdf also attached to post
Problem is, when i select the pulse and direction setting and save to eeprom I am unable to get any movement out of the motor or response from the drive.
I am very sure that the pulse train is coming out of the motion controller, I can enable the drive using the software or input pin but still no movement.
What am I missing here?
thanks
