584,814 active members*
5,148 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > ATC draw bar for BF30/PM30 type of bench mills "BT/ISO30 spindle"
    Apr 2019
    6
    Just a thought,..
    Is it possible to modify the spindle shaft of this type of mill with drilling quill to take a gripper or ball lock ATC draw bar for stud type 30 taper tool holders (BT/NT/ISO)?
    Re: ATC draw bar for BF30/PM30 type of bench mills "BT/ISO30 spindle"
    I believe it is possible to regrind an R8 spindle for BT20, not sure about 30. Then it is just a matter of building the drawbar.
    Most go for TTS though, it's just a lot less messing around. Of course BT20 would be far superior in many cases, TTS is adequate for most of the work you would do on one of the machines as well.
    A well setup TTS drawbar works pretty well, but it certainly can take some work if you are building from scratch like I did.
  1. Boring a 1-3/8" hole on a 5/8" thick 3"x3" cold rolled steel bar
    By dalianharley in forum Tormach Personal CNC Mill
    Last Post: 05-14-2014, 02:49 AM
  2. Plastic "Fingers" For ISO30 Tooling?
    By HunterSnow in forum CNC Tooling
    Last Post: 12-30-2011, 08:14 PM
  3. "J" head type "millport"(tiwan,1980) clutch
    By marksbug in forum Bridgeport / Hardinge Mills
    Last Post: 08-17-2009, 04:48 PM
  4. New "Universal" type mills?
    By clockmaker in forum Uncategorised MetalWorking Machines
    Last Post: 08-09-2004, 06:02 PM
