585,996 active members*
4,834 visitors online*
Results 1 to 1 of 1
    Jun 2013
    Movements are not correct
    Hello,
    i have problem with correct moving of Measuring probe.
    I want to measure points in following order : 1,4,2 and 5
    Attachment 482660
    Measuring points 1 and 4 are correct, but 2 and 5 are on different plane (MAC), and when its starting to measure point 2 probe go to position 4 and then, rotate to position 2 (it will crash with stock and i need to stop machine).
    Idea is when measure point is finish to go up (Z250) and then to next point.
    Can someone please check CNC code in attachment i think my post processor is bad.
    Thanks in advanced!
    Attached Files Attached Files
  1. Strange movements
    By pedropin in forum MadCAM
    Last Post: 04-03-2020, 08:02 PM
  2. Diagonal movements
    By dp341 in forum Chinese Machines
    Last Post: 05-21-2017, 01:01 PM
  3. First movements......
    By bald9eagle in forum DIY CNC Router Table Machines
    Last Post: 08-25-2014, 05:38 PM
  4. Erratic movements, inconsistent action. uncontrolled movements
    By dusty41 in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 01-06-2014, 11:36 AM
  5. Slow movements
    By cnclies in forum Mach Mill
    Last Post: 12-13-2011, 08:27 PM
