I set p080=4 now the vfd runs on startup and I can't stop or reset
And YES IKNOW I F ed up. Anyone now how to shut down/stop
Ok, I have the Manual so check to see if F000. =0 if (1) the Parameters are locked you can disconnect the spindle while trying to get it working again
Just set P080=0 back to (0) for normal operation, if you can't Reset this Parameter, you will have to do a Factory Reset, and reprogram the Drive to suit your spindle specs
Mactec54
