585,992 active members*
5,978 visitors online*
    Jun 2003
    242
    331 x axis fuse error
    I have a Matsuura with a Yasnac MX3 control, it is the base control for the mid 80s Seikos controls and I am getting the 331 X axis fuse alarm, I can't find a fuse and the problem started as an intermittent issue so it's unlikely it's a fuse issue. Any help would be appreciated!
    If you know of a service person for these old(1989) controls in the Toronto, Ontario area, that might be a help as well.
    Oct 2021
    Re: 331 x axis fuse error
    Hi L98FIERO, in older controls, it`s very common issue misscontact produced by defects in soldering. In case of relative large components this problem is most frecuently. Try to check (or better re soldering) critical components, obviously the fuse support, and components with big heatsink are the "most wanted pcb killers" . Also yo can try to test the fuse, with an multimeter check it, also check it shaking the fuse during the test, in ordert to discard an internal failure in fuse.
  1. x axis not moving - blown fuse shorted FET
    By SEK22Hornet in forum Centroid CNC Control Products
    Last Post: 09-16-2019, 12:24 PM
  2. G540 Panel Build.. To Fuse or Not to Fuse
    By stingray_65 in forum Gecko Drives
    Last Post: 06-30-2016, 12:02 AM
  3. Kaiser Extension KA6x3.937 (10.331.661) - NEW
    By AlexP in forum For Sale Only
    Last Post: 07-23-2015, 02:37 AM
  4. Mazak 331: Misopearation No. 2 (chuck)
    By leiryll in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-06-2015, 01:14 PM
  5. BP series 1 x axis fuse blowing
    By keebler303 in forum Bridgeport / Hardinge Mills
    Last Post: 07-08-2006, 08:23 PM
