584,866 active members*
5,198 visitors online*
    May 2015
    16
    Adira Press Brake PMO 13530
    Hello..
    My Adira Press Brake PMO 13530 with adcontroll 10.
    The machine can't indexing/home position. This is used machine and new for us.
    any advice or manual book will be very appriciated.
    Regards,
    Komang.
    May 2015
    16
    Re: Adira Press Brake PMO 13530
    Quote Originally Posted by komang View Post
    Hello..
    Regards,
    Komang.
    Hello again..
    Today I checked the machine and tried move the axis using diagnose mode. For Y axis and X axis working good, only R axis alarm AX1152 Axis R1 forward LS sometimes backward LS depends where you move the axis. I tried disconnect LS cable to servo amplifier but the problem still same.
    Last I disable R axis on the parameter, and the machine can indexing/home position. But when we use the machine for production, for the closing the speed is very low. I have adjust speed on the axis parameter (fast descent parameter and work descent parameter) but nothing change.
    I remember previously on Amada HFT we have same problem because there are jump cable/brige on the robot connection. I don't know it's same problem or not and I need help to figure it out.
    Any help will be very appriciated.
    Regards,
    Komang
  1. Converting Conventional Hydraulic Press Brake to CNC Press Brake with PC
    By aadityadengle in forum Uncategorised MetalWorking Machines
    Last Post: 08-13-2023, 05:23 PM
  2. Replies: 1
    Last Post: 01-21-2023, 12:32 PM
  3. Adira press jitter error
    By joepesterey in forum Bending- and Punching Machines
    Last Post: 07-07-2022, 01:23 AM
  4. Need Help with ADIRA Press Brake
    By buszkock in forum Uncategorised MetalWorking Machines
    Last Post: 04-27-2017, 05:08 PM
  5. Adira QHA press brake manual
    By kenkad in forum Bending, Forging, Extrusion...
    Last Post: 01-08-2011, 04:41 PM
