Re: Preparing lb15ii-m for transport
The machine normally has shipping brackets that prevent the X andZ axes from moving during shipment. The turret is supported from the bottom using an L bracket that bolts to the bottom of the X axis and there is normally a bracket that goes between the Z cross slide and the base. You should be able to spot some holes where the bolts go. Check the electrical cabinet because sometimes they put the shipping brackets in there.
