585,981 active members*
4,470 visitors online*
IndustryArena Forum > Employment Opportunity / RFQ (Request for Quote). > RFQ (Request for Quote) > North America RFQ's > Needing two 6061 spacers turned from 2.25 OD/ 1.75 ID tubing
    Sep 2007
    181
    I own and run a machine shop however we only manufacture our own products that we produce and sell directly. I need to get a couple extensions turned from 6061 and since our lathe wont accept a 2 inch diameter so I cant do it my self inhouse.
    In the attached pdf file there are two parts, essentially the same part just two lengths.
    I am looking to get one of each made for a total of two parts.
    Machined surface tool finish is fine. Factory extruded surface finish on all non machined surfaces is fine.
    Thanks in advance for your consideration. Please pm or email me at [email protected]
    Oct 2021
    10
    Re: Needing two 6061 spacers turned from 2.25 OD/ 1.75 ID tubing
    Hi, I have emailed you, Please send me the drawings.Thank you
    hi,i have sent email.pls check.
    Jun 2023
    20
    Hello,
    Hope you are doing well!
    This is Eva, Project Manager of Best Prototypes, a reputable prototype manufacturer in China. I am writing to see if there are any possible for us to be your supplier?
    We have the services for your parts.
    -CNC machining (3 axis. 4 axis. 5 axis).
    -3D printing (SLA, SLM, 3DP,FDM).
    -Vacuum Casting (silicone Mold),
    -Fast Tool / Die casting.
    -Machining (Bending,Punching,Cutting,Welding).
    -Injection mold
    If you have projects that need to quote, you can send it to my email, then attach the materials, quantity, process and finish you want.
    I will give you a free quotation as soon as possible.
    Kind Regards,
    Eva.
    Email address: [email protected]
  1. RFQ - Simple Turned Steel Spacers
    By LateNight72 in forum North America RFQ's
    Last Post: 09-01-2022, 06:43 AM
  2. RFQ Turned 6061 Parts
    By rxtreme in forum Employment Opportunity
    Last Post: 07-10-2015, 04:20 PM
  3. Deburring of a large qty of turned spacers
    By Pharkas in forum MetalWork Discussion
    Last Post: 06-27-2012, 03:08 PM
  4. Gash repair- 6061 AL tubing?
    By Scuff in forum Welding Brazing Soldering Sealing
    Last Post: 10-30-2009, 04:28 PM
  5. 6061 SPACERS
    By EDPACECAR in forum Employment Opportunity
    Last Post: 06-03-2009, 04:43 PM
