585,712 active members*
3,722 visitors online*
Thread: Mazak T-Plus
    Dec 2021
    Mazak T-Plus
    I had a fault with a T-plus control. It would not power up.
    QX084:
    Led1= solid green
    Rest off
    QX141:
    Led1=solid green
    Led2= solid green
    QX 722B:
    Led1= solid red (watchdog error?)
    Led2= solid green
    Re-initilisation was not possible. First i tried replacing the 722 but no fix. I then replaced the whole secondhand QX141 complete with another qx722 and 422 but used my own cartridges. I was then able to re-initilise and the machine started and it ran ok for a few hours,
    However on startup today the problem re-appeared! The machine now will not power on with the exact same leds showing. Removing the qx539 or qx524 does not effect the led status. Surly it is unlikely for a spare card to fail this quickly? Something must cause this problem to occur again so soon. I cannot re-initilise the control.
    Mar 2010
    5
    Re: Mazak T-Plus
    mazak t-plus often has problems with capacitors. all smd cap on cpu card , smd cap on 722, power unit 12v and other check
  1. Mazak MYSTERY. HOW do you clear this ANNOYING Mazak alarm??!!! NOBODY KNOWS!!
    By Mill&Lathe in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-03-2022, 01:55 AM
  2. Please help me about Mazak FJV-250-Mazak Fushion 640M cnc milling machine
    By DUCVUONG in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-16-2021, 02:03 AM
  3. Mazak QT-10 T2 manuals --acct w/ mazak?
    By CDTINC in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-21-2012, 05:09 AM
  4. Mazak 6pc with machine Mazak 400n
    By anva in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-17-2010, 08:30 AM
  5. Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem
    By sting_dot in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-22-2007, 02:20 AM
