585,908 active members*
3,734 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Diy built 5 x 9 ft. router that has a gantry that is vibrating when is moving.
    Dec 2013
    26
    Hi Need idea about solution to make my gantry stop shaking .
    My servo don't gerk or vibrate . the gantry is moving from back to front. when making part , the part as nuch ,
    the gantry is square with the y axe .
    I need some clue !
    Go see it , Thanks
    https://photos.app.goo.gl/bTsU16J6G1sCd1Gm9
    Apr 2018
    133
    Re: Diy built 5 x 9 ft. router that has a gantry that is vibrating when is moving.
    The permissions on your Google account photos are not set correctly for public viewing. (AKA your photos are not visible)
    Nov 2013
    4370
    as far as I can see your gantry is in two pieces with one rail on each and the ballscre/ballnut in between. I would guess the vibration is because
    the two halves of your gantry are flexing in the opposite direction, one half going back towards the rear of the machine while the other half is flexing forward
    to the front of the machine.
    Try grabbing the bottom of the spindle and pull it towards the front of the machine. How much force does it take to twist the gantry by 0.1 inch? It should take many
    tens of pounds-force but looks like its not that stiff and more than a few pounds would cause the deflection. I think your gantry is twisting like a soggy noodle.
    Craig
  1. New Diy CNC fixec gantry x-z and moving table Y
    By xtal in forum Tormach Personal CNC Mill
    Last Post: 03-09-2017, 01:07 AM
  2. Moving Table, or Moving Gantry? (For Router)
    By Cryptonic26 in forum DIY CNC Router Table Machines
    Last Post: 04-20-2011, 08:38 AM
  3. fixed gantry router built in solidworks
    By dlpaul in forum DIY CNC Router Table Machines
    Last Post: 02-08-2011, 09:40 PM
  4. Open Team Cheap DIY CNC Moving Gantry Router
    By pminmo in forum DIY CNC Router Table Machines
    Last Post: 08-19-2007, 07:59 PM
  5. Moving Table vs Moving Gantry; Dremel vs Router
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 03-28-2007, 02:48 AM
